2012 Avensis 1.8 Valvematic oil filter tool
Mo_h
Hi all,
Can someone help me please.  I require a tool to remove the oil filter on my car. Any recommendations?
I have found this one but not sure if its the correct one?
https://www.ebay.co.uk/itm/253263708267?mkevt=1&mkcid=1&mkrid=710-53481-19255-0&campid=5338785333&toolid=10029&_trkparms=ispr%3D1&amdata=enc%3A1bw5CunY0RKGzVFDWgbY-IA83&customid=s%3AGS%3Bgc%3AEAIaIQobChMI84rdpvax9gIVjN_tCh1eqABnEAQYCyABEgI-HPD_BwE
Thanks in advance
1 hour ago, Mo_h said:
Hi all,
Thanks in advance
this is not the correct tool and it will not fit your car engine. You tool needs to have smaller outside diameter. Here it’s the one which would do it.
https://www.amazon.co.uk/DEDC-Flutes-Compatible-Corolla-Highlander/dp/B01MRWJVDI/ref=sr_1_26?crid=NLG69CTYFFA6&keywords=prius+oil+filter+removal+tool&qid=1646591835&quartzVehicle=111-11837&replacementKeywords=oil+filter+removal+tool&sprefix=Prius+oil+%2Caps%2C183&sr=8-26
10 minutes ago, TonyHSD said:
Thank you Tony. Ordering right now.
You are welcome 👍
Can I add, that I use fibre washers and replace them every oil change I do. I also only use 0w20 oil as the preferred grade. I posted on the subject many years back.
