Orginal RAV 4 PHEV charging cord/cable ?
HSDish
Do You think this is a orginal Toyota RAV 4 PHEV charging cord/cable ?
Mine came in a sealed bag with stickers all over it with Toyota model numbers. (Both cables the same)
The other cable looks like this and seems more orginal Toyota to me.
Both look similar to the 2 cables that came with mine. One for charging from normal 13amp outlet (Mode 2), the other for an untethered wall charger or public charger (Mode 3).
PS. Don't confuse Mode with Type! Both cables (plugs) are Type 2.
The grey mode 3 cable is very thick and stiff, not at all like the mode 3 cable that came with our Prius 2018 PHV. That one was much more similar to the mode 2 cable, with blue connector and thin ,flexible cable
The mode 3 cable that came with mine is much thicker and heavier duty than the mode 2 cable (I can measure it later if you want to compare) and has rubberised black plugs rather than blue plastic. I presume because the mode 2 is only carrying around 10 amps where the mode 3 around 32 amps. Was the Prius pulling 7kw, or more like 3.5kw? That might be the difference?
Sounds like our mode 3 cables are the same.
The Prius was pulling 3.5kW and it seems, as You say, reasonable that this is the difference in thickness
My mode 3 cable is 16mm thick and here are a couple of photos of the cable rating and the product label on the plug.PXL_20220307_110300255_MP.thumb.jpg.c5ebbe0bdbf2e8a76ba3d69593a1e4f5.jpgPXL_20220307_110234357_MP.thumb.jpg.55535c7a469dbba933ce2675fccafd26.jpg
Mornin' all......so did mine, supplied with the car in 2 separate sealed bags.
1 Heavy duty 7kw lead & 1 light duty 3kw granny lead.
Barry Wright, Lancashire.
Thanks again.
I´ll measure mine and look for lables
I bougth my car used as a demo so... no sealed bags
Checked mine and it´s exactly the same as Yours. Thanks.
