brake system warning light
pollykettle
HI everyone, hope your all well and good.
Looking for some help please. As above the warning light comes on for a bit then off again. Any ideas???
Thanks in advance
Make and model would help eh smiley thing
Auris 1.6 V-Matic Icon+
Hello Paul - welcome to Toyota Owners Club.
Moved to the Auris club.
is it a yellow warning ⚠️ light and red light or only red light? Have you checked brake fluid level in the reservoir? Can be a low level, or perhaps a speed sensor or anything else along the system and best to run a diagnostic first to check for fault codes and take it from there. 👍
Thanks for the reply TonyHSD.
Red light only and stays on for about 5mins. Good shout i will check brake fluid level first before taking it for a diagnostic. Thanks again Paul
You are welcome.
Red brake light can also be illuminated if the hand brake it’s not released properly as there is a switch on it somewhere, this needs checking on too after you have checked brake fluid level.
Regards
Hi TonyHsd,
Problem solved, low brake fluid which led to a %$(ed rear caliper. Fixed and jobs a good yin.
Again thanks for your help really appreciated Paul
11 minutes ago, pollykettle said:
Hi TonyHsd,
You are welcome. I am glad all been sorted. 👍
