Could any member tell me the torque settings for my Aygo wheel nuts. I broke my wheel brace trying to undo them. So now need the settings as to not over tighten.
Thank you
103 Newton metres or 76 foot pounds on the 14 inch alloy wheel of the mark 1 car
Thank you for information.  I will torque the nuts up the correct settings and hopefully not snap my new wheel brace.  Thanks again
It is important when tightening bolts and nuts to the correct torque settings not to use any grease or oil on them. If they are old and rusty you can do the following trick: undo all nuts and place them on a paper towel, spray them nicely with wd-40 and leave them while working on the car, wipe the dry with clean cloth or towel before putting onto the hub, torque to the specs 👍
