Hi all
We've just bought a 2002 previa 2.4 auto and as I'm going through it and discovering everything I've found a 'problem / query' . Where do I find the rear washer jet ? I've got the switch on the stalk for it , the wiper works , I've found the pipework under the bonnet and it sprays water when I activate the rear wash (different from the front ) , but I can't find a nozzle. There's no nozzle on the spoiler or by the wiper arm and there's no pipework or connections on the arm/spindle.
Can anyone help please ?
Thanks , Adam
I assume it would be the same as my Estima...underside of the spoiler is a little oblong slot (between the centre brake light and the actual rear window glass)..the nozzle is housed in there and you can't really see it.
You probably need to remove the spoiler to get at it...or maybe via the rear brake light lens.?...I'm not sure.
I did have to remove the rear centre brake light lens once to renew the bulb but I don't recall seeing anything to do with the washer (but then I wasn't looking..!)
