Will a 2ZR-FE fit in first gen Toyota Passo/Daihatsu Sirion /Perodua Myvi?
OddFellowinMalysia
I seen a video of a couple guys put a 2ZR-FE into a Yaris 1st gen. I thought will that work on a Sirion as they have similar engines. The K3-VE is the same as the 2SZ-FE except the transmission bell housing mounts are not the same and the accessory belts are completely different.
Will the  2SZ-FE fit in stock on a Daihatsu Sirion. If so then the  2ZR-FE should fit in no problem other than the mounts.
