Avensis 2.0 d4d 2011 turbo change
Danamos11
Hi has anyone changed a turbo on a 2.0d4d  2011 before? Doesn’t look to bad to do. The turbo is rattling and got really low boost 😩😩
Have you checked there isn't a leak in one of the pipes? That's a lot more common than the turbo going bad! Usually the turbos only get problems if the car isn't maintained, as they are quite dependent on regular high quality oil changes to keep all the bearings clean and well lubricated.
How do you know it's low boost? On your other thread you started off suspecting the 5th injector?
