aygo x-press Vvt-1 mileage problem
my wife has an aygo and although everything on the dash seams to be working , including the speedo , the mileage is not increasing and just stays on the same reading.
has anyone in the brains trust come across this before ?
Is it dealer serviced, if so it should be covered, if you have a scan tool you can check the mileage stored in the ecu and check for any codes, if the mileage is different you know the cluster is bad
A 2018 Aygo should still be covered under the 5 year/100,000 mile new car warranty, unless it was an insurance write-off. I would check/book it in with your Toyota dealer.
  • 4 months later...
sorry for late response guy`s , It was an insurance write off , so not covered by any warranty.
strange that the speedo works fine , just not recording the milage.
