Quick question can you add distilled water to the panasonic Battery as car has been parked up for 5 months before a full charge at home  as its currently showing that the Battery is completely flat.
In a word, NO
It is an AGM Battery IF it can be saved in needs a long slow charge at low current <4 amps with an AGM charger what may take 48 hours
Toyota part number
28800-28070
superseded by
28800-28071
Panasonic or Yuasa
S55D23L (left hand negitive)
You need to replace it with the same Battery type dont cheap out - be aware it's £200-230
Cant I use a normal charger on it, iv got a ring charger charges 12v and 24v fast and slow charge or would you suggest thats not compatible for it thanks for the heads up.
AGM batteries prefer a controlled (intelligent) charge, typically they charge slowly at a higher voltage and low current than a lead acid
you can use a normal charger, but i would monitor the charge with a multimeter, as you may kill it otherwise
Ok appericate that I think I'll try the easiest option 1st put Battery back in and go for a nice long drive, see if it hold charge.
Iv been searching for a new Battery with a little price difference both come with the same codes a lexus rx450H and the toyota estima both batteries are exact same apart from year they can be used for.
Lexus one is from 2008-2015 28800-31291
Estima one is 2006 onwards
everything Looks exact the same codes fitting etc.
Can anyone shed any light whats the difference please.
..hmm...they don't look the same to me.
The model quoted by @flash22 - 28800-28071 (same model I bought for my 2008 model)
Buy Genuine Toyota 2880028071 (28800-28071) Battery for Toyota Estima. Prices, fast shipping, photos - Amayama
The Lexus model you quote - 28800-31291
BATTERY & BATTERY CABLE. toyota | Toyota
Make sure you're buying the correct one....
The codes for the Battery are exact same i was wondering if just the Battery were just the same the only difference i can see is the year they are for. Lexus 2008 onwards a day estima is 2006 onwards
Hi all slightly different subject does anyone now how much distilled water should be in a non amg Battery ie how much should it be above the plates inside the battery
6 hours ago, Zeddi said:
The codes for the battery are exact same i was wondering if just the battery were just the same the only difference i can see is the year they are for. Lexus 2008 onwards a day estima is 2006 onwards
yep they are the same spec - S55D23L (left-hand Negative) temp sensor on the corner
2 hours ago, Eddiefh said:
Hi all slightly different subject does anyone now how much distilled water should be in a non amg battery ie how much should it be above the plates inside the battery
4-6mm above the plates on a lead acid, if you are wetting the cells make sure the Battery hasn't bulged - an older Battery that has been charged too much will sulfate - If you have stop/start it will be an EFB type Battery - DO NOT wet the cells
4-6mm above the plates on a lead acid, if you are wetting the cells make sure the battery hasn't bulged - an older battery that has been charged too much will sulfate - If you have stop/start it will be an EFB type battery - DO NOT wet the cells
Thank you flash22
  • 2 years later...
Hi, I bought JDM estima 2008 hybrid. its been 3 months that car was on dock. When I got it, I jump started it, and a smeel came from inside the car. After I while I realized its from Battery. may of acid. The Battery was heating too much, and heat sensor also rang, I shut down the engine and sensor went off. But car is not starting without jumping. I drove it for 50-60kms but still the same thing. Is Battery blew up. if yes, what's the equivalent OEM available in Canada for that battery with temp sensor. I went to canadian tire, and they dont have these temp sensor batteries. Can anyone please help. Thanks
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
