Driver's side front wing misaligned with door seal.
BanzaiQ
I've recently got the IQ back from an MOT and I noticed that the lower part of the front wing (driver's side) is slightly misaligned with the adjoining driver's door seal.
 Can anyone tell me if it's an easy thing to put straight ? I've noticed the same thing on some other iQ's also. I've attached a before and after photo to illustrate.
The misalignment corresponds with the car having recently had a new o/s front tyre for the MOT. And I'm surmising that it might be connected to this because it's very close to where the car would've been jacked up I reckon🤔
yes its been jacked up at the wrong place, iirc the wings are bolt on - i would have a look under the edge and at the sill at that point
just looked it up, 2 bolts and 2 seals at the bottom of the wing
Pics for reference
https://www.ebay.co.uk/itm/324588225521
Ah' I see. Yes I reckon the tyre fitter has been a bit clumsy then... Thanks for the response. Hopefully it's an easy fix🤞
  • 2 months later...
Hi @BanzaiQ
I have the same issue on the driver side of my IQ3. Did you manage to resolve this issue?
