2008 Yaris noise
Mo_h
Hi all. I have a 2008 Yaris 1.3 petrol. It's dont around 49K miles. I changes the front brake pads in Dec 2020, but now the rear drivers side is making noise when accelerating. Any ideas of what it can be? Sounds like a ringing sound
Probably the break pads need changing. They have a small metal pin that contacts when the break pads need changing.
I assume yours are drum brake rears? Might help to jack the corner up and spin the wheel freehand and see if you can replicate the sound.
Does it also happen if you're coasting along without accelerating? What about when braking?
The noise is more prominent when accelerating. Sometimes when coasting you can hear a slight noise from drivers side rear
Exhaust problem? Have you tried blocking the tailpipe and listening for leaks?
I haven't tried that.
I thought it might be something common. My MOT is due soon so I might just wait and see if it gets picked up or will either change rear brakes.
