Strange issue with Android Audio in Yaris Mk4
RickyC
Hi All,
I've a strange problem with AA ( with wirecd connection ) on my Yaris Mk4.
It works fine but after the end of a call ( incoming or outgoing it's the same ) the audio is witche from car Speakers to smartphone ones.
My phone is a Xiaomi Note 9 Pro with Android 11 ( MIUI 12.5.7 ).
Someone else has got the same problem ?
Currently the only fix that I've found is to disconnect an reconnect USB cable.
Both smartphone and app are up to date ( AA app version is 7.3.620524 )
I've also tried to remove and reinstal the app and delete the smartphone from multimedia memory and repeat pairing but the issue is still present.
I would suspect the USB cable as it seems AA is dropping the USB after BT is used
there is also an update for the touch2
I've already tested varioius USB-C cables but nothing has changed.
Where can I find the update?  I think that Yaris Mk4 uses Touch3 ( I've the 8" display without Nav )
It's the touch2 update is listed under the TSB's on http://www.toyota-tech.eu - £4 an hour plus vat download the TSB PDF and the download link is inside
there has been another update this year since i posted this
(You missed out the "-" in your embedded link... - that link above goes nowhere on a direct click)
That's odd, it changed the text but not the url
there you go sir, tsb are under the repair tab at the top
Hi Bob (hope you see this in time), I've just purchased a 1 hour sub on the site but all I get when I try and access a TSB is rotating circles as if there's something up with the site? Could you try it please? (as long as you have a current sub of course)
Toooo late! ☹️
That's €4 down the drain 😪
  • Haha 1
  • Sad 1
Get a refund, sometimes you need to log off and log back in for the sub to take effect (had the exact thing happen) got you sorted anyway 😉 - give me a bit to get the files sorted
had a list of other thing i needed to look up anyway
