Head Unit issue for Wigo Gen 2
JL Maala
Got error message in my Toyota Wigo Gen 2 Head Unit saying.
“Program memory is low. You must select one task to close, or increase the amount of program memory if available.”
when I clicked on the ok button on the upper right, nothing happens. I already tried pressing the reset button and removed Battery terminals but still the same.
Please advice. Thank you.
Hi this is UK based forum
iirc the wigo is a Asia built car for that market so not something we get in Europe, the car its self is a rebadged Mitsubishi Mirage (now discontinued in the UK) i have never seen that sat nav model
If your system uses a micro SD card for its maps (iNav/NaviTel) remove the card before turning the car on, a quick google shows it behind the little flap top right (Map)
  • 9 months later...
i have this kind of problem too on my toyota wigo 2019 headunit, did you fix it?
