Which fuse for Front Dash Cam
GoonerKev
Hi, can anyone tell me please which fuse I can piggy-back off in the fuse box under the footwell for hardwiring in my Dash cam. Thank you
The fuse to use has been mentioned previously in a thread about fitting dash cams. I will see if I can find it tomorrow if nobody comes up with the answer before then.
Which vehicle is the dash cam being fitted to - the Yaris as per your profile or an Auris (which is the forum you've posted in)?
Many thanks dannyboy413, I'm sure I piggy-backed from the 15amp "Power Outlet" fuse on my old CHR but can't remember.
FrostyBalls (Mike), my Auris which I'm getting in a few days time. Thought I had changed the profile from Yaris to Auris, I will check that now, thank you.   Corrected👍
Yes the 15amp power outlet used to be the cigarette lighter socket.
Thank you Bernard 👍
My dash cam came with a OBD ii wired plug, works like a charm and had no problem with the Battery drain.
Stuff all this connecting to the fuse box ect.
Maybe have a gander on Amazon
I cant be messed around with fuse boxes either.  My connection is a usb adapter in the aux (cig) connecter. Only a few inches of cable visible the way I have run it.
Yep that’s the one same on the latest corolla.
Thanks Chris 👍👍
