Tyre sensor ecu writing
the fox
Got techstream all works fine till I try and code a new tyre sensor I get all the codes on the screen change number 1 to the new code but can't write to the ecu got a message "ID registration failed due to a communication error with the ECU while in initialization mode."
How are you communicating with the car from Techstream? USB Serial OBDII cable or bluetooth?
you need to be in tech stream under the correct model code and specs otherwise it will fail
I'm using a Vim lead via USB all goes well till I ask it to write to the ECU it shows me the old codes I change number one and that's as far as i get
Ok. Is Techstream showing your correct vehicle type number and VIN number once you are connected? (without doing anything else)
Some of the cheaper USB J2534 pass-thru VIMs seem incapable of writing the TPMS data properly via techstream.
e.g. This type will work with techstream, but when it comes to programming TPMS sensor IDs, it will fail:
https://www.cardiagtool.co.uk/cheapest-mini-vci-for-toyota.html
This one does program TPMS:
https://www.eobdtool.co.uk/wholesale/vxdiag-vcx-nano-toyota-diagnostic-tool.html
I know I have both. First type failed to program TPMS on A RAV via TS. Second type worked.
The software finds the vehicle showing Vin number etc. my USB lead says it's version 1.4 if that's any help
See @shcm's post above.
The Mini VCI is Can Bus only, there is a VAG-com lead workaround for TS, what's a cheaper alternative to the VCX Nano, you can do a cable test in TS it will show what the VCI does
Let me see if i can find that thread (will post an edit)
https://mhhauto.com/Thread-FAQ-Toyota-Techstream-on-VAG-K-CAN-Commander-1-4-ELM327mod-and-VAG-KKL-409-1-k-line
ps. is this for the RAV4 as it's posted in the yaris forum
