Toyota Yaris verso Weeping intake manifold.
amazighman
Hi.
I noticed there is a mist of oil underneath the intake manifold and has covered front of the engine block.
Thinking that might be the intake manifold gasket , car seems to run ok  though.
Should I replace it or just leave it well alone , ? Wouldn't that cause a vacuum leak?
Cheers
More than likely, the cam cover gasket has gone crispy with age and/or heat cycles
intake gasket - 17177-21030 (old number 17177-21020) - the aftermarket tend to reference the old No.
Cam cover gasket - 11213-21011
Victor Reinz are very good gaskets
Thanks a lot
Seems to be air intake , unless old spillage unlikely
Clean it up with degreaser, don't think It's anything to worry about
