Mk1 pre-face headlights
just_jon
Hi all, still on the hunt for a good deal on some pre-facelift mk1 Auris headlights to replace my UV-damaged ones.  I don't really want to go spendy with OE jobs.  On the pattern parts side, does anyone know if there are LHD & RHD differences on the Auris?  I don't want to get lefties and end up blinding other motorists.  Some of the better deals are from European pattern manufacturers.  The second question is on the level motors, some headlights are marked as not having them, does this mean they simply don't come with motors and I can just transfer mine (I have checked they work properly), or does this mean that they don't have the correct moulding for the motored version?
Before anyone says 'just polish them', the damage is on both the main outer skin and the inside lens which you can't get to.
Cheers,
Jon
Yes there are lhd and rhd headlights
03/2009 is a change over, so you need to know when the car was built
Can you PM me your VIN
81170-02470 (Valeo 043461)
81130-02480 (Valeo 043462)
Thanks, very much appreciate the help.  Have PM'd.
The numbers above are incorrect !!
Correct numbers by vin are....
81130-02510 (Valeo 043466)
81170-02500 (Valeo 043465)
Cheers, I don't suppose the Valeo numbers are quoted on the system?  Struggling to match stuff up.
