can some one tell me where the IAT sensor is on the Starlet SR and how to get to it.
Any help would be great.
I have been told it could be faulty.
Many Thanks
Matt :wacko:
I am assuming that stands for Intake Air Temperature.
If its anything like a Sera or Starlet turbo it will either be
1) mounted into the air filter housing (Sera)
or
2) mounted on the front edge of the inlet manifold on LHS (Starlet Turbo)
If it is the air temp sensor then it is located at the top of the airbox. If u pull it out it will look like a pointed plastic thing that goes into a rubber grommet. (sorry bout the poor description)
