Toyota Avensis T27 Front Windscreen Washer Nozzles required
Inpresmoj
Hi, I need 2 x bonnet washer nozzles for my 2010 Avensis.  Looking on eBay a lot of them say universal fit and they are only £5 for a pair, Toyota where several times that, is there anything i need to look out for before ordering, or can someone recommend a eBay listing as universal fit can sometimes not always be the case.  Thanks
Is it the jets, there maybe a T/Y splitter what has a 1 way valve this gunges up and blocks
Universal = Fits nothing
there a 3 different types of jet by angle type -2, 0 and +1
valve  85321-28020
https://www.ebay.co.uk/itm/183263423391
https://www.ebay.co.uk/itm/383397856248
iirc the valve is on the underside of the bonnet
im sure @TonyHSD has had this problem (among a few others)
My Mechanic says its the jets they have completed gone they cannot be fixed and water is pumping up to them fine, he said i can just order replacements off eBay.
flash22 There are 3 Different types of jets, how do i know which one i need? or is it just personal choice where you want the water going
So i need to stay away from the universal fit ones then and buy a OEM Toyota part
When I first had my car back in 2015/16, my washer jets of my T27 were not working properly. I checked the jets and hoses,  cleaning the jets and all the hoses and connections were good. In my case a slightly kinked hose and a partly blocked nozzle. I also made sure to use pre-mixed washer fluid, because of water scaling. I never use tap water! Since then I have had no issues with my washer jets.
Change the 3 way valve first, the washer jets hardly ever fail, the valve is the cheaper
thanks for replies so far, with my mechanic thinking its the washer nozzles and im not completely sure which ones to order along with posts on here about its quite often the valve im thinking of taking it into Toyota because my health hasnt been great recently and this has been going on a while and id just like it sorted.
Use the plus 1 nozzle if you really need to replace it, the plus or minus relates to the angle the spray goes on the screen, better off being plus 1 as that is a bit higher on the screen
