Brake discs 2009 Verso Executive.
I'm about to order brake discs from autodoc. But they say they come in two sizes. 320 mm or 297 mm in outer diametre.
How can I find out which is right without removing the tires?
If you post as much information about your car as possible, someone might be able to help you.
Are they for the front or the rear?
Also, are you in The U.K.?
Send me reg will see what I can do I’m at work now so can do straight away
