reversing bleeps not working
Maggie3
the reversing bleeps have stopped working on my Yaris 2011. any suggestions please
Check the lining inside the boot as there may be a small switch that disables the sensors - used when towing, etc. If there is, it may have been knocked into the off position.
Thank you. I will look in the morning
5 hours ago, Maggie3 said:
Yes one reversing light
OK, that suggests the problem is the beep system and not the switch, etc, that decides when reverse is selected.
If Frosty's suggestion comes up blank you'll probably need to find the control box for the system and check voltages, trace wiring, etc, to work out what is wrong. Hopefully just a bad connection connection somewhere, in which case just wiggling the wiring might fix it - for a while at least.
Thank you both for your help. Having looked in the boot I have decided I can go no further due to my age so it will have to be a garage job I'm afraid.
