hybrid models may produce a squeaking sound?
JanisLP
Hi, i found this online, Prius hybrids may squeak when brake pedal is applied, released. Toyota reports that 2004-07 Prius hybrid models may produce a squeaking sound whenever the brake pedal is applied or released. According to the car maker, the noise is most obvious when the key is in the ready mode and the vehicle not moving. , but i have yaris hybrid 2020,3rd version.  With same sound issue. Is any idea how to resolve that ? Thanks 😉
Is it the actual pedal squeaking? The older Yarisusuesusis were sometimes prone to that with the clutch pedal; Just required some lubrication in the pedal box in that case IIRC. Might be a similar thing here?
When you push on break pedal to start up car then coming up this squeaking sound, feels like some oil not there ! Yaris hybrid 2020 automatic.
