Toyota auris diesel loss power
Saif zadran
I have toyota auris diesel sign maf Air flow is high it runs smoothly but once a day or in 2 days it starts loosing power specially at junctions or roundabouts keep pressing accelator nothing happens suddenly it jump but when I turn off for 1 minutes and start again it's all good when I take it to garage they said it's air flow meter I changed it but nothing changed any advice please
How many kilometers does the car have? There are many factors that can cause this to happen Try cleaning the EGR valve
Thanks for reply
My car is driven 74000 miles what happens is my car drives very smoothly but suddenly it's losses power and engine light comes on P00BD MAF "A" Circuit Range/Performance Flow Too High
but when I switch off and on again everything is normal i have changed MAF sensor dpf sensor i think mechanic cleaned EGR
I had something like that happen to me back in March 2020. On the shop, the mechanic tried to see if cleaning the EGR improved, to no avail. Ended up replacing the EGR with an aftermarket DENSO unit, and it solved the problem. That was over two years ago, since then no such problem occurred again.
And yes, I had the same issue, turned off the car, it disappeared and the car functioned normally.
In my case, replacing the EGR solved the problem.
