Does any one know how easy it is to take off the toyota Badge in the front nose cone??? Thanks
They're usually VHB double-sided taped and/or clipped in place - 90975-02195 on to a base 75312-0H020
Edited for clarity
https://www.ebay.co.uk/itm/255294892897
Thanks for that
How do you get it off the car
Carefully by releasing the clips if it's just the chrome part, pop the lower centre clip first that should make the top 2 clips loose (the centre top is a locating peg) use a plastic trim tool or a taped up flat blade screwdriver
Thanks will have a look at the weekend
