Hi, guys i wonder if u can help me out here.
i found out yesterday that my 2 front brake discs are warped. So i headed into town today to order some new ones. The problem ive been faced with is :
will slotted and grooved rotors fit. Without having to change the caliper.
and what size - i keep getting asked - are the brake discs ?
Cheers
Damien
if you mean by slotted, that the discs are vented then YES they will fit and also grooved will fit as well no problems.
you just need to make sure you get the right size. as a tip for mesuring your brake disc diameter, don't measure the diameter of the disc, your likely to get it wrong because the hub sticks out and is in the way or if you measure the back you need to get it lined up through the center
instead measure the circumference and divide by pi (3.141592654) and that'll give you an accurate diameter and reduces the error too.
hope that helps mate
sanj
