Hi
My wheels do not go back when i turn in a curve. i need to manually turn the steering wheel back.
I have made a wheel adjustment so it should be okay but the problem remains.
Does anyone have any idea what the problem might be?
Hi, most likely it’s a fault with your power steering. You need to find out if it’s an electric or hydraulic. Maybe can take the car to a garage for check and quote for repair or replacement.
Good luck
