Position Light housing / holder melted?
daved27
Hi All,
I just went to replace the passenger side front position light / side light, and the burnt out bulb appears to have melted itself to the holder. Does anybody have any idea on what I should search for / part number for a replacement?
Auris Hybrid 2011
Hi, have you tried to remove the old bulb and install a new one? I had previously similar issues and after carefully removing the old one the new then works without problems 👍 . You can try that too and if it doesn’t work for you then you will need a new bulb socket 81275-02070
https://japancars.ru/index.php?route=catalog/toyota&mdf_id=12218&area=EU&cat=166510&blk_id=8101
From eBay used or Toyota dealer new.
