Can anyone tell me where the fuse is that would operate the rear wiper.
2016 model.
Thank you, Cathy.
Just now, Cath Sanderson said:
Can anyone tell me where the fuse is that would operate the resr wiper.
Thank you, Cathy.
Mk1 (up to 2014) or Mk2 (2014 on)?
It is in the driver's side fusebox. Inside the car, below the right hand air vent and the switch panel, is a small cover for the fuse box. Remove the cover and the fuse for the rear wiper is number 5 (15amp fuse).
It's stubborn to move, is it on plastic tabs? Will continue tomorrow.
Thanks.
The image below, although of a left hand drive, seems to show a clip on the one edge (lower edge??).
If it helps...................
Aygo-KGB40-2014-2018-fuses-location-rhd.thumb.jpg.669b957fb370072282917ce2589912a7.jpg
