What alloy wheel manufacturers fit the EP91 Starlets due to the position of the wheel nuts? :bookworm:
i know renaults do,i think vw and vauxhall do as well
virtually all. PCD 4 x 100 is a very common fitment.
However, the offset varies hugely and this is as important.
off the top of my head its 35mm offset but need to check that for sure.
wheels off most hondas with 4 studs fit, i think the same manufacturer supplies wheel hubs to honda, toyota, mazda and nissan as they all take similar wheels.
Im sure the offset is 38mm but i may be wrong. I know its no more than 38mm and no less than 35mm. All yaris wheels will go straight on, as will wheels from corollas etc. Most after market rims shud fit with 4x100 PCD and 35/38 mm offset.
Have a nice day B)
thats strictly not true. I tried to fit my SR wheels to a '95 civic. the stub spacing is correct, but the honda hub is too large. the wheels may have to be machined to fit
Speaking of wheels;
does anyone know who deals with a company called 'wedsport' i've seen a mint set of wheels which will look killer on my EP82 (not here yet, but coming soon!!)
Starlet is 4x100 ET38
Look at some Mx5 wheels some of them are correct
As for Wedsport JDM wheels and will cost you lots of £££ to get a set if you want JDM looking rims for reasonable money try www.rarerims.co.uk
Simon
