Looking for recommendation - Auris 2015 - Head unit Upgrade
Suku
Hello All,
I have a 2015 Toyota Auris 1.8 TS. I would like to upgrade / replace the head unit so that I can use Apple car play and other functionalities (music, phone, navigation, reverse camera etc).
Could you please recommend which is the best Head unit in the market? If possible, a link please. Thank you.
What's your budget ? Best head unit on the market anything thing from £2K - 5K+ you could easily spend £20-30K on an installation
13 hours ago, TonyHSD said:
Here perhaps some ideas for cheaper ones. What is important imo is to have apple car play and android auto. 👍
https://www.halfords.com/technology/car-audio/all-car-audio/?prefn1=singledoubledin&prefv1=Double
Thank you Tony...
Max 500 Eur.
SPH-DA230DAB
https://www.pioneer-car.eu/eur/products/sph-da230dab
SPH-DA250DAB
https://www.pioneer-car.eu/eur/products/sph-da250dab
Where are you located ?
95% what's on aliexpress is utter rubbish, it's cheap for a reason - no support, warranty or little to no instructions - guaranteed until you open the box
  • Like 4
Agreed with Bob, buy well known make to get a quality screen, sound and functionality. 👍 Those cheap ones does not even get a proper radio signal.
3 hours ago, flash22 said:
SPH-DA230DAB
SPH-DA250DAB
I'm from Netherlands. Does the above Head units fit in Auris? I read in some thread that the video is not displayed while reversing. Any comment?
You will need the relevant adapters eg. steering wheel controls and camera retention
Connects2 do install kits - but im not sure on availability in NL
On 4/14/2022 at 5:54 PM, Suku said:
Hello All,
I have a 2015 Toyota Auris 1.8 TS. I would like to upgrade / replace the head unit so that I can use apple car play and other functionalities (music, phone, navigation, reverse camera etc).
Hi mate, I've got an original Toyota Auris 2015-2018 unit with Satnav and phone music functionality. All yours for £200.
Hi There, I too have the original Auris Satnav with me. But I want to upgrade to other headunit in which I can use the Apple carplay function. I assume the one you are offering does not support Apple car play. Thanks.
The Auris never had AA/AC, go with a decent quality aftermarket unit
On 4/19/2022 at 4:52 PM, Suku said:
Hi There, I too have the original Auris Satnav with me. But I want to upgrade to other headunit in which I can use the apple carplay function. I assume the one you are offering does not support Apple car play. Thanks.
Hi mate, my one's the 2018 model, which has the extension module which gives your more features. So you can connect your iPhone via the AUX cable and play Apple Carplay, if that doesn't work you download the AutoKit App and play via there.
  • 1 year later...
Hi, wonder if anyone can advise me on trying to get a Toyota Auris 2015 Sat Nav and cd player, the one I have the touch screen doesn't work so bought another one from e-bay but the plug in sockets were different at the back. The model that I currently have is:
86140 - 02330 made in Czech Republic 02.01.15
There seem to be plenty of models 86140 - 02030 on eBay but the only one with the same model number as mine was different at the back, can we modify the plug sockets or should I take a chance and buy that one?
The back of my Sat Nav looks exactly as the same as the back on the one Suku and Mr Strong posted in April 2022 but the front of mine is different as it has 2 dials for the radio and 3 buttons either side of the screen (the same as model 86140-02030).
Any advise would be appreciated.
86140 - 02330 is 05/2014 - 05/2015 (touch2)
86140 - 02030 is pre 2014 (touch)
the sat nav modules are completely different between the 2, 05/2015 onwards uses the touch2 with the glass front (no knobs)
not sure if a later one will work with the reverse camera, and it will need some minor changes to the wiring eg. https://www.ebay.co.uk/itm/354924203288 or https://www.ebay.co.uk/itm/225781727590
as for the non-working touch screen, i take you have tested it with the sat nav module disconnected
