Gear Box oil/fluid?
FuzzFaceFreddy4
Is there a dipstick for this on a Yaris , and if so, where is it located?
(2009 Yaris 1.3 petrol)
Hi, no dipstick on the gearbox. Oil check via refill plug.
Not for the gearbox, it's one of the fill-it-until-it-leaks-out-of-the-fill-hole-and-you're-done types.
Cheers - and where can I find the refill plug?
Many thanks!
Refill plug usually is located close to the differential and approximately same level as your drive shafts where your drain plug below them or bottom of the gearbox. Always undo refill plug  first to make sure you can refill with oil if you decide to undo drain plug and replace the transmission fluid.
2 hours ago, FuzzFaceFreddy4 said:
You are welcome
