Yaris 2010 MMT stalls
k9commanderz
Hey guys,
I've been trying to move my car but have been unable to.
It cranks but the minute I let go of my brakes the car stalls, it feels like the car is in high gear because it tries to move off quickly but stalls.
https://youtu.be/d1CdWf7JrwM
it's an automatic and also no error codes are being displayed
Also now, when I start the car and move the gear to E while holding down on the brakes, the car would make a noise as if it's trying to change gear.
1 hour ago, flash22 said:
Has the car been stood for a period of time ??
Nope, I drove it on Saturday and it was fine, it's only today that the issue is happening and now I am getting clutch overheating warning light. Normally in the morning , when I start the car , it would shake like crazy even after warming it up for 5+ minutes. After riding for a bit, it would go back to normal. But today it wouldn't budge.
Put it in 1st in M (Manual) try to give it throttle while holding the brake, does it do it reverse ? The car hasn't been clamped, has it ? (No road tax)
i would say it needs a clutch and a new clutch actuator - it's not a cheap job
no clamp on the car. The clutch warning light stays on now. Trying to find to find a mechanic that can change new clutch and actuator for semi autos
Most places can do them, they choose not to as they can be problematic
A main stealer will want the thick end of £1500-2k replacing the clutch and both the clutch and shifter actuator
Clutch change procedure for the MMT
INF12215_GB.pdf
good lord that's expensive. Probably worth just selling the car at this point. I'll see what I can find thanks
oh yes the MMT's are fine till they act up, the Mk3 yaris changed over to the CVT Auto from 2012
if you can find a place to do it, expect £5-600 as a minimum, the actuator is £190-300 on its own if at fault
