Starter battery replacement, T27 diesel
Micken
Exide Avensis battery change.pdfAre these Exide Battery change instructions for my car correct. if so looks like a main dealer only option.  On  my wifes Nissan note Battery change you can only loose the radio code, but on the Avensis the steering angle sensor and central locking needs resetting. Are these easily resettable after Battery change.
2 hours ago, Micken said:
Exide Avensis battery change.pdfAre these Exide battery change instructions for my car correct. if so looks like a main dealer only option.  On  my wifes Nissan note battery change you can only loose the radio code, but on the Avensis the steering angle sensor and central locking needs resetting. Are these easily resettable after battery change.
I changed my 2014 Toyota avensis 2.0d4d Battery to losing nothing not even sure if those Toyota touch 2 headunits have a key code as I didbt put one in mine all just lit back up car going great and we'll when I bought my car the Battery was done came from the British car auction that way car only had 38k on it business EDT real clean car
I have the petrol version T27 2009 Tourer. I change the car Battery, an Exide I got from Tayna. The only issue I had was that the ECU had to relearn the idle settings. I found a quick way to reset the idle back to normal. Nothing else was needed. The radio is not coded, just need to do radio memory presets. The windows will need the quick down hold then up hold to Parking brake not affected. The diesel might not be affected at all.
3 hours ago, Konrad C said:
I have the petrol version T27 2009 Tourer. I change the car battery, an Exide I got from Tayna. The only issue I had was that the ECU had to relearn the idle settings. I found a quick way to reset the idle back to normal. Nothing else was needed. The radio is not coded, just need to do radio memory presets. The windows will need the quick down hold then up hold to Parking brake not affected. The diesel might not be affected at all.
i found that idle problem with my car when needed a new Battery but all good now she driving great .i have a fresh kinda expensive autel 808 pro and well there is software on it when you are putting in a new Battery in to the car it sets up the car for the new Battery so dont ware out batterys as quick so it says i never tried it out yet
15 hours ago, 2009joe said:
i found that idle problem with my car when needed a new battery but all good now she driving great .i have a fresh kinda expensive autel 808 pro and well there is software on it when you are putting in a new battery in to the car it sets up the car for the new battery so dont ware out batterys as quick so it says i never tried it out yet
I remember the following post -
