Yaris 2017-2019: remote open/close windows & rear fog light
Vins213
34 minutes ago, flash22 said:
Driver side front window (front left):
UP yellow/red with red 8
DOWN yellow with green 5
Driver side rear windows (rear left):
UP gray/black with yellow 12
DOWN gray with black 13
Passenger side front window (front right):
UP orange/purple with white 16
DOWN orange with pink 15
Passenger side rear window (rear right):
UP blue/brown with red 10
DOWN blue with green 18
Positive red 12v with 20A fuse to grey 6
Negative black 12v with W-B 1
ACC ON white with ACC ON mirror 21
DOOR LOCK green 12v+ with yellow 4 lock door
Green/black lock 12v- and purple top window not connected
So, I have to:
1. reinstall the 20A fuse instead of the 7.5A
2. cut the wires and join the double color to the switch wire, and the single color to the motor wire
Correct?
1. reinstall the 20A fuse instead of the 7.5A - Connected to pin 6 grey
2. cut the wires and join the double colour to the switch wire, and the single colour to the motor wire - Yes
Thanks Flash! Tomorrow is the day
Well...replaced the 30A fuse, but....the driver side window only works in UP, not DOWN, not AUTO UP/DOWN...I checked the main switcher and if I put the little switch on DOWN, I have 0 with + in pin 5 and - in pin 1, also in AUTO with + in pin 4 and - in pin 1...with + in pin 8 and - pin 1, with the little switch in UP position it works
I think the main switcher is dead, the 3-4-13-14 fuses are ok
Can I still install the mod?
IMAGE 2022-05-05 18:05:33.jpg
Question: why this installation mode?
As it only needs to power the windows up when signalled by the lock, the window switch changes polarity to make the motor go forwards or backwards
Ok thanks!
BTW I think I have to change the main switcher 😞 74232-0D690
I can still install the mod with the switcher not 100% working, right? The other windows should work fine
Doesn't work 😔 the windows work but nothing happens when I close the car with the remote..the scheme is this, with the double color wire to the switcher and the single color wire to the motor:
Did you check for the lock pulse, pin4 should be 12v+ when locked, and pin 1 is ground, i take it you left some windows down to test
is this the same module or a replacement ?
Didn't check the lock pulse, I was a little disappointed 😔
yes I have put down three windows (except driver side), closed the door and locked the car...0 windows movements
same module, the new one I think it will be here on Wednesday
and pin 1 is ground
I don't have connected any wires on pin 1, the green/black for -12 lock is unconnected (same for the purple wire for top window)
Good, leave it like it
The reverse voltage probably killed that module, TBH
Uhm, so can I check the module?
The 30a fuse is gone again after I have switched down the two rear windows (old switcher, tomorrow I will receive the new one)
New switcher installed, works everything...but not the mod, how can I check if it is dead or if I have joint everything correctly?
did you change the closer module it killed the window switch so likely killed that too
to test, wind the window down, get out of the car, press and hold the lock button on the fob for 5-10 seconds
I have changed the entire master switch assembly (H1), the window (or the windows) doesn't go up even if I press and hold the lock button for 10s
My colors inside the door for the L/UL
1629027902_Schermata2022-05-10alle14_54_22.thumb.png.f245d65ce97c063f57981184e6411b48.png
This the scheme I have followed:
1099371513_Schermata2022-05-01alle21_41_14.thumb.png.b15878979f214dd1d2b8c3ba30922d0c.png1628247024_Schermata2022-05-01alle21_41_17.thumb.png.fee2b4f3da763ad0826621683b08b249.png
1894533408_Schermata2022-05-11alle17_31_55.thumb.png.a4e77bf190b120bc61aabb5682c69243.png
1132261956_closemoduleedit.jpg.01b604443317090b5e671c5b568f89a0.thumb.jpg.f73aa26be40bca396ff8a0e7d4657d37.jpg
 Door lock - Remove the green from pin 4
with a window down, doors closed, ignition off, ground the Green/black
So I have to connect the Green/black to the ground of the door? There is a ground point with a B/W wire on the bottom of the door
just for testing only - you only need to ground it for 5-10 seconds
Ok, so I can pin the green/black to the ground of the door and disconnect the green from pin4
the green/black is a negative trigger you just have to ground it for 5-10 seconds - eg. Touch the wire to a ground to simulate a lock signal
Ok, I'll try in minutes...after that what can I see? What can I do?
Nothing happened...cutted the green from the yellow, grounded the green/black in the spot in the photo for 10s, faked a door close pushing the door button
