Yaris 2017-2019: remote open/close windows & rear fog light
Vins213
@flash22 Hi Flash, what can I do? Restore everything or change/fix the mod?
yes put it back as you found it, that's the chance you take with these cheaper Chinese items, they lack any protection circuitry or ability to handle loads
I didn't find any mod not China-brand
i can, but you don't like the price
Around 100€?
On 4/23/2022 at 3:49 PM, flash22 said:
No the mk3 does not have this function/ability, the Mk3 needs an aftermarket solution from the likes of Clifford, Laserline or Cobra (now Vodafone) the latter 2 being based in Italy
eg. Clifford 530T
help me flash 🤣 didn't found anything
But it says:
'This module allows two electrically operated windows to be closed from a distance if used with an alarm or remote controlled module. For security reasons, the remote control system must be programmed with a window output of the controlled type.'
so only 2 windows?
Up again, I'm searching for a kit that allows front windows go up when locking the doors, and front windows go down when unlocking the doors
Clifford 530T does 2 windows up and down but it needs a 3rd button or fob for the down or vent function
So I cannot use that, I haven't the vent or 3rd button
vent is where it drops the window down say 40-60mm to "vent" the car on a hot day
got it, but I haven't the 3rd button
do you have keyless entry or do you have to push the fob
I have to push the fob with key/remote
Fit a decent alarm with its own fob ? - do you have an ignition key or is it push button start ?
I have this
IIRC there is a 3 button version of this remote, not sure is the receiver in the car is compatible tho
Hi you can purchase a fuse removal clip but sometimes a special tool is located inside the fuse box.
But since you cannot bamage a blown fuse use long nose pliers.
sigh, sob....is there a compatible kit that I can buy with a remote for the vent or open/close?
  • 9 months later...
hi Bob @flash22 I haven't find anything this winter and the hot days are coming soon...what mod could you recommend to install?
I found this
ONE
TWO
THREE
N°3 is a plug&play with a strange button-combo for activate roll up/down
