Hi all new to this forum can any one help with this there is a fuse for the alternator on a 2005 Aygo where is it the location and can it be replaced if it's blown I read a thread on the internet that the fuse can't be replaced you have to fit a new fuse box seems a bit strange but maybe true any info would be appreciated
This link may also help :-
These tend to blow if jumpstarted with the wrong polarity
Remove the Battery - unbolt the fuse box - remove the lower plastic of the fuse box - remove the 2 bolts/wires - insert the fuse put it all back together, Toyota upgraded the alternator fuse to 125 amp
pic of a blown link, new fuse (fusible link) goes in between the 2 bolts
don't rule out the Battery being shagged
the Toyota Fusible link is. 90982-08297
you may find them called a MIDI fuses, but the 120/125 can be a pain to get (not online)
  • 2 years later...
Remove the battery - unbolt the fuse box - remove the lower plastic of the fuse box - remove the 2 bolts/wires - insert the fuse put it all back together, Toyota upgraded the alternator fuse to 125 amp
don't rule out the battery being shagged
Can you pls. tell me how can I remove the cover on the fuse box to access the Alternator fuse? I have  electrical system failures in my Aygo KGB10 and the alternator will not charge the Battery so i suspect that the Alternator fuse has blown 😞
Also is there any means to check if the alternator fuse is blown by using a Multimeter? I was thinking of removing the Battery first and then put the Multimeter in Connectivity mode and then touch one probe to Alternator B+ and the other probe to Battery Positive wire connector and listen to Beep to verify if the fuse is blown or not?
unbolt the fuse box from the car you can then unclip the bottom cover
