USB port is not working well
Jako_84
Hi
I have an Auris 2017 and when usb charging port is not working as well. It is charging when i start the car and then disconnect after awhile. I tried to use the Apple original lightning but did't solve the problem. Any idea please?
Thanx
The USB only charges at 500ma so will charge very slowly, invest in a quality cable like an Anker 3.3ft lightning cable they are Apple Mfi Certified - Apple's iPhone/iPod/iPad cables are utter rubbish even Apple admit it
over time and use the USB port can become a little slack and some manufactures plugs a not the best
Don't rule out that the port on your phone may need a good clean as they can build up dust, dirt and pocket fluff
  • Like 3
@flash22
Thank you for the tip. I’ll try another lightning and clean the port!
 i hope it will work
My usb failed on My aygo, claimed under warranty and replaced, could faulty ?
