Hi, hoping someone will be able to advise as I am reading conflicting info. I’m heading to Europe in a few weeks for a nice break and need to know about the beam pattern. I have a 2019 sports tourer in excel trim with the dual led headlamps. I have read online these are a flat beam so do not need the eurolite stickers? Can any confirm this? I read through the user manual and nothing is mentioned about driving abroad. On old BMW’s I never had to do a thing and the GPS sorted it all for me. Thanks.
You can check with your dealer for an official answer, but otherwise just turn them on in dipped mode and point the car at a flat wall/board/something and look at the beam pattern - If it's flat from left to right and you can see a fairly sharp cut-off then it's probably okay.
If the left-side is illuminated noticeably higher as it is with normal halogen bulbs, then it will need beam deflectors.
