Does anyone know what that noise is when reversing in the corolla 1.8 and 2 litre
thanks
If its in EV mode it will be the pedestrian acoustic warning noise which is louder in reverse.
Sounds like a UFO / metal scraping noise.
Does Corolla have the beep beep sound when reversing like Prius/Auris or these are only for cars with the joystick gear selector?
No it doesn't.
3 hours ago, dee123456 said:
No it doesn't.
Thanks. 👍
It beeps *inside* the car, but not outside (Well, unless you have all your windows wound down :laugh: )
  • Haha 1
So it’s beeps then. Same as Prius and auris .
Yeah, the same beep beep beep beepbeepbepebebebebebeeeBEEEEEEEE in any car with reversing sensors.
Outside the car is the UFO-with-the-handbrake-on sound
No annoying reversing beep beep sound when selecting reverse like there was in the Auris. Only beeps when sensor detects close proximity to an object
The noise I was referring to sounded more like a scraping metal sound on reverse only. The sound you may get when your brakes have worn out
That was the first thing i noticed when i collected my new car. I then realised it was a sound to warn pedestrians there's a car near.
Thanks 🙂
