25 minutes ago, flash22 said:
Yes, if someone can unplug there's and take a pic that would be good
edit.  @Techfreak's car the wiring is up to the socket but not into the door loom, LHD will be slightly different and may have different wiring as its a newer model
i will see if there are any door looms for sale
Hi Flash...yep understand now...
More wires at the back of car loom guessing from the mirror switch...
Less wires going to the door via the connector....
just marked the pins so it makes sense
Green - Adjustment
Yellow - Mirror heater
Green - Adjustment
Wow.....Superb.....Thanks for that.... really useful.
On 5/11/2022 at 8:46 PM, flash22 said:
yes, pins 16, 17 and 10 🙃👍
RHD only - drivers side loom
https://www.ebay.co.uk/itm/323872124947
RHD only - passenger
https://www.ebay.co.uk/itm/265263079254
they may swap over or just need stripping for parts
Hi Flash....do you how I tell what version the door wiring harness is ?
With or without electric mirrors.
Are they the correct ones above ?
As I realise folk might resell the old door harness without electric mirrors.
Thanks.
Look for the mirror plug - its just forward of the speaker plug, worst ways you pull what you need out of the used part and add it to yours
Red is the mirror plug, yellow is the speaker
  • 2 months later...
Screenshot_2022-07-25-09-30-59-868_com_ebay.mobile.thumb.jpg.103f2d26e66cbe9017903df04f6f8ab2.jpg
More info ..
Photo above showing 2 missing pins on new replacement cables. Connector also inverted top pins at bottom.
Green - Adjustment
Hi Flash, Is there any chance you can identify what all the other pins are ?
The reason I ask is... on the new replacement cables I am looking at buying have 2 pins missing....but are on my original cable in the photo above. The 2 left pins below the top 3 pins.
Thanks for any help.
That's a big ask, It will take time as it's across multiple schematics
1 Door speaker - red or black
2 Lock detection - Beige (driver's side)
3 Lock detection - Light blue (passenger side) Green (driver's side)
4 window up - black (swaps to pin 5 on the driver's door)
5 window down - light blue (swaps to pin 4 on the drivers' door)
6 window power - white
7 Door speaker - White or yellow
8
9 Lock switch trigger+ - Light green
10 Adjust M+ - Green
11 Heated mirror 12v+ - black
12 Door lock motor, unlock - Green
13 Ground - white/black stripe
14
15
16 Mirror adjust horizontal - light blue or yellow
17 Mirror adjust vertical - light green or white
18 Door lock motor, lock - Red
8
14
15
Absolutely fantastic. Thank you. Most appreciated !!!
  • 7 months later...
I am interested did tou mange to connect the new mirrors at last. Thank you
Yep....changed both manual mirrors to electric and heated. Also changed the mirror covers to Chrome. 😉
  • 3 months later...
8
14
15
Hi guys, I'm also interested in replacing my manual mirrors with electronic mirrors, but I would also like it to fold. I have a folding motor and a complete switch with a folding button but does anyone know with 2 cables it needs to attach to?
I think I already figured it out I'll let you guys know next week
