ICE always on
Vins213
Hi! I think I have a big problem: the ICE doesn't turn off, never! I have a 2017 Yaris, the EV indicator on panel is always off even if I have it on, the ICE doesn't turn off after the classic few minutes. 23º C outside, the SOC goes to full Battery and the ICE still goes on...eco mode or not eco mode, when I push the EV mode I have a display message: 'EV not available at the moment'
the little vent on the rear is at max power I think, cleaned the vent and the filter...what can I check?
The engine temperature starts to 0 to the half of the temperature indicator bar and the ICE still goes...and the SOC goes to full charge with full green indicators (and ICE still goes)
you will need to run a diagnostic first to see if there are any faults recorded. Then you can use app and suitable obd 2 adapter to check hybrid system if all ok . Carista is a good obd 2 adapter and apps that you can use are Hybrid Assistant, Dr. Prius, to check the condition of your hybrid Battery and system.
1 minute ago, TonyHSD said:
you will need to run a diagnostic first to see if there are any faults recorded. Then you can use app and suitable obd 2 adapter to check hybrid system if all ok . Carista is a good obd 2 adapter and apps that you can use are Hybrid Assistant, Dr. Prius, to check the condition of your hybrid battery and system.
I have an iPhone and some apps are totally different or not existing
carista seems ok
carista seems ok
Yeah, these above are on android. Carista will do it for an iPhone. Your problem seems to me like something to do with higher temperature of the Battery or inverter issues. When you start the car engine is running and meanwhile is charging the Battery. When engine reaches normal temperature should turn off but it doesn’t for some reason then overcharges the Battery. When hybrid battery is full charged the engine is running again to discharge the battery to more appropriate levels and so the whole system continuing to  charge and discharge the battery. Battery cooling filter , grill and air ducts to check again., and if all ok then you have to look at the inverter. What you can do also is to disconnect the 12v battery for few hours and then reconnect and try to see how it’s working afterwards.
Good luck
Thanks Tony, hope to fix it!
The 12v Battery may be low as you have had the doors open working on the car, take the car for a long drive or leave it in ready mode for an hour or so and let it charge, if you have the A/C on the engine will kick in
if in doubt, disconnect the 12v Battery for 15 mins or so and let things reset
17 minutes ago, flash22 said:
The 12v battery may be low as you have had the doors open working on the car, take the car for a long drive or leave it in ready mode for an hour or so and let it charge, if you have the A/C on the engine will kick in
if in doubt, disconnect the 12v battery for 15 mins or so and let things reset
lol, you know more than me about my car, that's fun 😆
I was for 30mins out for shopping and now the problems seems vanished
Problem solved (I hope), the car needed a reset...hope it doesn't appear anymore
Well...turning on the car appears 'PCS not available' and I cannot start the car...12v Battery dead or near to death I presume
i think so, you may be able to charge it - as it's an AGM Battery it needs to be charged low and slow <4 amps
it may be that window closure module draining it
10 minutes ago, flash22 said:
i think so, you may be able to charge it - as it's an AGM battery it needs to be charged low and slow <4 amps
Yes, changed a few minutes ago...that module is a killer feature LOL
Do I have to disconnect the mod or fix it?
Ahhh sh*t, here we go again....28°C outside, EV mode not available in any situations, ICE always on, the little underseats fan is going fast and the car is always with ICE on, from 2 Battery stack on a hill, the car doesn't charge any stack even if I was between power and eco...I have disconnected the windows mod, I have changed the 12v Battery and the problem pop up again, after 1 hour with the car closed and parked under an angry summer sun...the Battery filter is cleaned, also the fan...what can I do? 😞 no A/C powered on, never used N or B
also this, when I release the accelerator, the engine rev up a little bit and then slow down, even if I'm going 30kmph on the first half of eco, with 5-6 SOC
If you have an obd adapter like Carista and android phone you can download app that allows you to check Battery temperature, modules , voltage , cooling fan speeds etc, all these may help you out. Android apps : Hybrid Assistant, Dr. Prius . iOS app Carista works great 👍
When is hot outside temperatures 20C° and more you have to use AC to keep your cabin cool and the cooler air will also cool down the hybrid Battery
If you have an obd adapter like Carista and android phone you can download app that allows you to check battery temperature, modules , voltage , cooling fan speeds etc, all these may help you out. Android apps : Hybrid Assistant, Dr. Prius . iOS app Carista works great 👍
When is hot outside temperatures 20C° and more you have to use AC to keep your cabin cool and the cooler air will also cool down the hybrid battery.
I have iOS
so with the A/C the problem will shut off? I'm a fan of natural cooling 😂
2 minutes ago, Vins213 said:
I have iOS
I can not say 100% it will cure your problem but this is how you cool down hybrid Battery and it’s noted in the owners manual. I also don’t like ac and only use when 20+C° When too hot outside or after a long downhill my engine also is running, this is happening to discharge the Battery when is full . iOS also has apps to help you check you hybrid system.
I can not say 100% is will cure your problem but this is how you cool down hybrid battery and it’s noted in the owners manual. I also don’t like ac and only use when 20+C° Whn too hot outside or after a long downhill my engine also is running, this is happening tp discharge the battery when is full .
I think you are right, because the car was a little white oven with windows down...tomorrow we can touch 33ºC, hope to solve the problem with the A/C because is really annoying
Batteries are very sensitive to high and low temperatures so most BEVs use the cooling (and in some markets heating) system to keep the Battery in acceptable limits. Natural cooling is often not sufficient.
Ok, maybe a stable OBD...which one between 1 and 2?
1: OBD2 BT 3.0 or 4.0 or wifi MS-CAN
2: OBD2 BT 4.0 MS-CAN SW-CAN
What's the difference between MS and SW can? Wifi is better than Bluetooth
EDIT: ok, the MS-CAN is for Ford network, SW for GM...so I have to choose the SW-CAN, am I right?
tbh cooling is a non issue, most of the heat is in the inverter on a hybrid that is liquid cooled anyway
so what can I do? Today the car is ok, like nothing happened...I wanna buy an OBD like the 2 linked a few minutes ago, with an old android smartphone
I use this one and it’s very good. https://www.amazon.it/dp/B00YVHGTBM?ref_=cm_sw_r_cp_ud_dp_FJB6775CZDCSP0SKCTJD
Don’t know anything about these that you have shared. Perhaps the the more expensive one will be better.
Carista has a monthly subscription, I've already used the free month...I'll go with the number 2 even if it is bluetooth 4.0
