Iq 2009 ac dont work
Bernhard
Hi From Denmark
My ac dont work..the el specialist in ac have spend 9 ahours to tryv to fix it..there come no power to the compressor..it works..New head box is on..but still no power to the comp..he think now it can be a mecanik problem? Any idet here  Thanks he have be doing ac rep..fore 40years and have never giv up a problem..but now he dont now what to do..he have check all elvire to.Thanks
Bernhard
No power at all ?
Manual a/c or climate control ??
Has the A/C relay been tested, is the 10a HTR-IG fuse ok ?
Is the A/C relay being commanded on ??
Many Thanks  manual AC...they sai ..the fuse is ok. Same with relay... the power never come down to the comp....the computer sai..when they plug it in  no power.i think I get a sommer with no AC  ..
Thanks again..
Does it work if you feed it 12V, have you replaced the A/C amplifier ?
Does the outside temperature read correctly on the orange display ?
Has the pressure sensor been tested ?
Thanks..I will ask if all this have be don.. all that .
Tem are ok..right...Thanks..
Yes he have used another ampf..
Check the fuse
HTR-IG 10a
To diagnose the a/c amplifier, you need a scan tool or access to Techstream to look at the error codes
