I purchased a 1996 Toyota Estima Lucida 4x4 Turbo Diesel Right Hand Drive back in March.
I went to do an oil change and the filter on it was a Drive Joy V91112002.
Anyway I went to many many auto parts stores here locally in the US.  I can't seem to find an oil filter that fits this vehicle anywhere!  Any us versions of the filter that anyone knows of?
CAN YOU SUPPLY THE VEHICLE VIN / MODEL CODE AND HOPEFULLY COULD LOOK UP THE OE NUMBER FOR YOU.
Cxr200108213 is the vin number. Thanks!
Built - 02/1996
model - CXR20G-RRSET
Engine -  3CTE
Oem filter - 90915-30003
Mahle - OC 294
Blueprint - ADT32115
Bosch - P3365
As you are in the USA - nearest equivalent spec filters
Napa - Napa Gold FIL 1368
AC delco - PF2107
Wix - 51368
USA 85-86 camry/corolla 2.0l diesel (2CT ?)
a cross ref off eBay
OEM Interchange: 500147067, 51368, 586025, 586061, 71758855, 7605033, 7605033/4, 7605062/4, 821-OS, 85368, 862-OS, 90915-03003, 90915-30001, 90915-30001-8T, 90915-30003, 90915-50003, 90915300001, 90915300038T, 92368, 971608, ADT 32110, ADT 32115, ADT32110S, BC-1227, BC-1302, C-112, C-116, C-141, C1111, CO920, COF 100275 S
  • ASHIKA 10-02-212
  • ASHIKA 10-02-297
  • AUTOPART INTERNATIONAL 500147067
  • BAP/GEON 1111513
  • BECK-ARNLEY 0418133
  • BECK-ARNLEY 0410742
  • Bosch 0 451 103 365
  • Bosch 0 986 452 030
  • BOSCH 0 986 452 602
  • BOSCH 0 986 AF1 047
  • BOSCH 0 986 AF1 130
  • CEW FILTERS 3174010
  • CROSLAND 2080
  • CROSLAND 2202
  • IPS 41129
  • KOLBENSCHMIDT 50 013 821
  • KOLBENSCHMIDT 50 013 862
  • MEAT & DORIA 15033
  • MEAT & DORIA 15033/4
  • MEAT & DORIA 15062/4
  • MEYLE 30-14 322 0001
  • MEYLE 30-14 322 0007
  • NAPA GOLD 1368
  • REPCO 1111513
  • TOYOTA 04152-03003
  • TOYOTA 15600-64020
  • TRP DAF (TRUCK AND TRAILER) 1516299
  • U.F.I. 23.264.00
  • U.F.I. 23.476.00
  • VERA 1001386
Thank you so much man!  I appreciate it!
On 5/14/2022 at 7:41 PM, flash22 said:
Built - 02/1996
Engine -  3CTE
Mahle - OC 294
Bosch - P3365
AC delco - PF2107
Wix - 51368
  • ASHIKA 10-02-212
  • ASHIKA 10-02-297
  • BAP/GEON 1111513
  • BOSCH 0 451 103 365
  • BOSCH 0 986 452 030
  • CROSLAND 2080
  • CROSLAND 2202
  • IPS 41129
  • NAPA GOLD 1368
  • REPCO 1111513
  • U.F.I. 23.264.00
  • U.F.I. 23.476.00
  • VERA 1001386
Wow! @flash22 - that's what I call a comprehensive response!! Kudos! 💪🏼 👍🏼
