!st 10,000 mile service...............
Lawnmowerman
just had the car serviced (10,209 miles & 7 1/2 months old).
Tried to set up charging by MyT app but an error shows - dealer has not removed repair mode, this will automatically reset after 24 hours.  Great.
Had a look at the Visual Health Check supplied and apparently my N/S/F tyre is a Yokohama VR whilst all the others are Bridgestone HR - even the spare! I don't think so.
Fronts reading an even 6.5mm and the rears an even 7mm. The spare 3mm.
It also states - add 3 notes and they are only found on the invoice which are:
1: Remove rear window sticker (it was right at the top and I didn't even see it for months - hate any stickers over the rear window elements).
2: Carried out recall X4422
3: Carried out ECU software update
They couldn't hear the wind noise - not surprised as it was a wet day.
I had checked progress during the day via the MyT app and the latest info. showed that it moved 86yds at 8:30 (and still does - no updates since). It had in fact covered 7 miles since I dropped it off - it obviously goes off-piste when in repair mode so no opportunity to find out how they used it. The journey history does show a cascading series of 'E's on the display which I take it to be part of the the Hybrid Health Check process.
The invoice suggest that the hourly rate is £61.28 + vat (but FOC as I have a service plan).
Oh yeah mine is due too, although currently in a hire car waiting a windscreen replacement on mine  (going to be a week) damn thing has nearly cracked into 2 halves right up the middle.
And I always remove stickers too, partly because glass is made transparent for a reason, and partly because why should I advertise them without payment.
Ouch, that must have been some impact!
Nope, tiny pin ubik indent at start of crack line, already had a crack in another unrelated part of screen. Methinks something not right with this one!
Last RAV went back after 60k with only ever 1 minor chip repair.
