Does anyone know of a rear door cycle carrier that works for the Touring Sports, without the expense of fitting a tow bar?
IIRC the tailgate is made from a composite material around a metal frame & is not suitable to mount a cycle carrier to
Roof bars or tow bar mounted carrier are your options.
^^ THIS.
I bought some Cruz aero bars, and Cruz bike carriers. The whole combo bolts together and can be removed from the car & refitted in about 10mins. With the Corolla being quite a low down car, it’s easy to lift bikes on
15 minutes ago, Gray86 said:
^^ THIS.
Sounds interesting. How much did it all cost? I'm not wild about Toyota's prices for bars etc.
Or if you have the sunroof, tow bar only!
The advantage of a tow bar mounted carrier is also that it very likely will be compatible with your next tow bar equipped car. Roof bars etc. tend to be model specific.
I bought it all from ‘roof box.co.uk’ - easy to build the package of everything required
