Auris Scan tool
Bper
Hi guys,
Can anyone recommend a good reasonably priced scan tool that will read and reset fault codes .
Cheers
Bob
19 minutes ago, Bper said:
Hi guys,
Cheers
Bob
Hi Bob,
I personally use a Carista and have subscribed to their own app. They give almost dealer like option to scan, delete faults plus do some additional settings like auto lights , locking, ac automation etc. Here I have some example how it works.
One of the latest reply has pictures attached with options that you can choose and adjust. 👍
I got a cheap generic scanner with a screen, that i carry in the car with me, i think it was Launch brand, not sure exact model, but was like 15-20GBP.
At home i have Techstream cable, that works with Toyota's Techstream diagnostic (you need a laptop for it) and you get the same diagnostic tool as the dealer.
Cable is also like 15-ish GBP on ebay's and alike.
Hi Dean, is your Toyota's Techstream diagnostic compatible with Windows 10? or it only works with windows 7?
I don't have a newer versions because i have an older model. But it should work with win10.
I remember some workaround being needed few years ago.
Worst case, you install virtualbox with older windows, and install the tool there, it can work like that also.
I use a cheap generic "miniVC" clone Techstream cable, I used it with my win7 laptop at first, I was so impressed with it, s I bought an old XP Toughbook just for it.
I got the same one, bought it 3 years ago for 15 gbp on aliexpress.
Used few times, has enough info for a handheld device, and i like the screen, so you don't have to bother with phone connection.
Always keep it in the car.
I have the Techstream on an old XP netbook, Delphi diagnostic on the same netbook with it's own interface and Launch 129 diagnostic.
I have had the Launch since 2015 (£175 back then) and has improved over the time with free updates, but Techstream is better, especially on Toyotas obviously. The Delphi I use the least. Weirdly I have done more mechanic work on other cars (non Toyotas) than diagnostics, so not used the equipment much recently - brother has a Micra and a Renault Grand Scenic, so has to do suspension work on the Scenic and wheel bearing on the Micra. When had to used the Techstream a few years ago, it was to sort out the Avensis EPB caused by the Launch. Yes the wrong tool used wrong can cause problems!
I spotted the Launch 3001 on that well known auction site, yesterday, for £16 delivered. Item in U.K. (apparently).
