Head Bolts
DirtyMiner123
Should I torque up my Head bolts wet (lubed) or dry, new to the game anything is appreciated
  1. INSTALL CYLINDER HEAD SUB-ASSEMBLY LH
    1. Clean the threads of the cylinder head bolts and apply sufficient engine oil to the washers and threads of the bolts.
    2. Mount the cylinder head sub-assembly LH on the cylinder block (bank 2).
    3. U146717E03
      Tighten the 6 cylinder head bolts in the order shown in the illustration.
      20 N*m
      204 kgf*cm
      15 ft.*lbf
    4. Tighten the 6 cylinder head bolts further in the same order above.
      100 N*m
      1020 kgf*cm
      74 ft.*lbf
      Note:
      If the bolt makes a stick-slip sound during tightening, repeat the procedure from the cylinder head gasket installation after cleaning and completely drying the bolt holes and contact surfaces.
      Tip
      In that case, the No. 2 cylinder head gasket can be reused.
    5. U146718E03
      Loosen the 6 cylinder head bolts by 360 ° in the order shown in the illustration.
    6. U146717E03
      20 N*m
      204 kgf*cm
      15 ft.*lbf
    7. Tighten the 6 cylinder head bolts further in the same order above.
      42 N*m
      428 kgf*cm
      31 ft.*lbf
    8. U146728E03
      Using an angle gauge, tighten the 6 cylinder head bolts another 100 ° in the order shown in the illustration.
      Tip
      Temporarily install the appropriate bolt for angle gauge if necessary.
      Text in Illustration
      *1
      Temporary Bolt
    9. U146729E03
      Using an angle gauge, tighten the 2 cylinder head bolts another 100 ° in the order shown in the illustration.
    10. U146730E03
      Using an angle gauge, tighten the 4 cylinder head bolts another 50 ° in the order shown in the illustration.
  2.
Wet, unless specified otherwise.
Ah, that Subaru life, hopefully you straight edged the block and head or had them skimmed
