Bi Xenon Toyota avensis problems
4dema
I have  a 2012 Avensis with adaptive headlight and the highbeam on the left side doesnt work, do i have to replace the headlight ? No way of repairing it?
I checked the owners manual and though actual bulb replacement is not detailed, the manual states to have the bulb replaced by dealer. Apparently both low and high beam bulbs are of the same wattage 35w, but not sure if the same type. If you are prepared to do the bulb replacement yourself, then you could try and remove the bulb taking photos as you go. If you do remove the bulb, you can then know what bulb you need. Otherwise get someone qualified. Apparently the voltages can be very high!
