The wife's Aygo has just had a new clutch fitted,I drove it to work recently and noticed car vibrating on motorway at higher speed(60 plus)could new clutch be problem or could it be a tyre or tracking problem?
Usually tracking if it occurs on the motorway.
Getting wheel alignment checked today
Wheel balance issues are usually cause of 60-65MPH wheel wobble.
A clutch can cause a judder but you would usually feel it at clutch bite.
Some people fitting a new clutch leave the drive shafts attached to the gearbox and swing the box enough to get to the clutch but I'm not sure if it is possible on an Aygo, this method can cause stress to the driveshafts.
Thankyou,we ve had wheels balanced,still vibrating at 60 plus,will contact the garage that fitted clutch,get them to have a look
Certainly something not right and most likely related to the work done on the clutch.
I would take it back to them to have checked as soon as possible.
Will do
Clutch not aligned correctly. They need to redo all the work. Clutch jobs are precise but often been done in no time and without necessary equipment, as a result- vibrations, noises and premature wear of the new parts. Mechanics then blame the parts quality where actually workmanship was the culprit.
