Radio keeps fading out
Robert-ftm
Hi all,when I first turn the car on (09 Yaris)the radios signal is fine but after couple minutes it just fades out to static ?turn ignition off then back on all ok again till it fades out again but only on FM ? AM seems to be fine so can kinda rule out the arial I think, anyone else had this if so any idea of the problem
A Dashcam can considerably interfere with the DAB signal.
The radio is dying, it is called frequency drift. Not worth repairing, just replace the unit
Cheers pal for quick reply to this problem at least I know what it is now ,,,
One more question if I get a replacement radio are they coded , cheers
Cheers flash appreciate the info 👍👍👍
